RT-AC3200 Command Line Temperature
shez
Hi guys. Could someone please help me with command lines for CPU, 2GHZ, 5GHZ 1 and 5GHZ 2 temperatures. I have the stock firmware as its a lot more upto date than TP firmware.
Thanks in advance
Thanks Merlin. Any updates on when your next firmware update will be?
No timetable at this time, and Asus's recent changes in the GPL code is making it much more difficult for me to continue, as now I need new separate GPL from them for every single model I want to release - something Asus rarely releases at the same time. Right now for instance, I am only able to compile the AC87 and AC3200 models, and no idea when I'll have the necessary files to compile any other model.
So, I'm not sure yet what I'll do yet following this change.
Oh no. Sure you'll work it out. 378.55 - your most recent version I believe - what is that based on in regards to the AC3200 stock FW?
6117 for the main firmware code, 6091 for the SDK7 driver used by the AC3200.
Sent from my Nexus 4 using Tapatalk
cat /proc/dmu/temperature
wl -i eth1 phy_tempsense
wl -i eth2 phy_tempsense
wl -i eth3 phy_tempsense
