roblangston
That is unfortunate. I'm now at 20days 11hours uptime, still zero issues.
SimmoF, O-L-A-V posted in #15, that his test showed NVRAM size: used -53737 bytes, with 77335 left, pretty much proves it's more than 64kb, a screen grab would would be nice if anyone has time to put on up. Happy New Year.
Thank you for your reply. I was using fw version 3.0.0.4_380_7994Clayton, what FW version did you use prior to upgrading? Cheers.
Thank you for your reply and suggestion. I had tried the previous version but had issues where the 2.4ghz would stop functioning. It would change the channel to Auto and would not allow me to change it. I had to restore the backup settings to resolve it. It was very annoying and happened daily. After talking with someone from Asus Tech Support, they sent me a beta firmware (RT-AC3200_3.0.0.4_380_7994) that supposed to fix the channel change issue, but it did not. So the current firmware version frequently automatically reboots the router. I'm currently using the latest Asuswrt-merlin Alpha version 382.3_alpha2 which seems to have fixed this reboot bug, but I have a couple minor issues (very slow remote access on port 8443) with it that I can live with. It's sad that Asuswrt-merlin does a better job with these firmwares than what Asus does. For now, I have no serious issues with the alpha 2 version and will continue to use it as I wait for Asus to release a newer version. Thank you.Clayton, you're welcome. Don't know how much inconvenience this would cause, but if you try revert to your previous firmware and the router stabilizes without sudden spontaneous or multiple reboots, unless there's an overwhelmingly convincing reason to put up with this version, you might want to hold on the previous FW a while longer. Sometime it takes a while for each version to settle down, sometimes it's due to power or other issues. Hope this helps, Cheers.
This has the exact same change log as 18338 but the Krack fix isn't mentioned anymore... And the new addition of "Improved WiFi stability and performance.". Hopefully I can run without the reboot scheduler now.
Also, I noticed the slow boot time issue and WAN led stuck red issue is fixed.
Rather than creating a new thread every time a new firmware is released for Asus RT-AC3200, I suggest we maintain one thread. This gives us one place to:
- Easily find reports about how previous firmwares functioned, if current is not that great.
- Subscribe to. Don't have to subscribe to a new thread every time a new firmware appears.
Current version
RT-AC3200 Firmware Version 3.0.0.4.382.50010 (2018.01.25)
FW Download
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC3200/FW_RT_AC3200_300438250010.ZIP
FW Download Checksums - Verified with 3 downloads
File: RT-AC3200_3.0.0.4_382_50010-gb0c6a12.trx
CRC-32: 7df3860e
MD5: 97f679cef6f1f371141e236a10653879
SHA-1: 9d7c6e6cdead7e7493271fda3ec71c4446e06fdf
SHA-256: 5f9a313db4f796001aaf92f80d9cfd366cb245d40f372e22a904561eaf937217
SHA-512: c87f15094429d2a6ab62448b2ead2ec5b3f25369f9d20f511cc0f1636ed1224bfde200d798ba6ee1356cf18c94298034a70a3015710734f50382e8961c677d5e
GPL Download (Not available yet)
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC3200/GPL_RT_AC3200_300438250010.ZIP
Changelog
https://www.asus.com/Networking/RTAC3200/HelpDesk_BIOS/
ASUS RT-AC3200 Firmware version 3.0.0.4.382.50010
Security fixed
- Fixed AiCloud XSS vulnerabilities
- Fixed XSS vulnerability. Thanks for Joaquim's contribution.
- Fixed LAN RCE vulnerability. An independent security researcher has reported this vulnerability to Beyond Security’s SecuriTeam Secure Disclosure program
- Fixed remote code execution vulnerability. Thanks to David Maciejak of Fortinet's FortiGuard Labs
- Fixed Smart Sync Stored XSS vulnerabilities. Thanks fo Guy Arazi's contribution.
- Fixed CVE-2018-5721 Stack-based buffer overflow.
Bug fixed
- Fixed CTF related issues
- Fixed AiCloud smart sync issue.
- Fixed client icon modification issue when client name includes special characters.
- Fixed AiCloud smart sync problem.
Previous versions:
ASUS RT-AC3200 Firmware Version 3.0.0.4.382.19466
FW Download
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC3200/FW_RT_AC3200_300438219466.zip
GPL Download
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC3200/GPL_RT_AC3200_300438219466.zip
Changelog
2017/12/0840.87 MBytes
ASUS RT-AC3200 Firmware version 3.0.0.4.382.19466
Security fixed
- Fixed CVE-2017-14491: DNS - 2 byte heap based overflow
- Fixed CVE-2017-14492: DHCP - heap based overflow
- Fixed CVE-2017-14493: DHCP - stack based overflow
- Fixed CVE-2017-14494: DHCP - info leak
- Fixed CVE-2017-14495: DNS - OOM DoS
- Fixed CVE-2017-14496: DNS - DoS Integer underflow
- Fixed CVE-2017-13704 : Bug collision
- Fixed predictable session tokens, logged user IP validation, Logged-in information disclosure (special thanks for Blazej Adamczyk contribution)
- Fixed web GUI authorization vulnerabilities.
- Improved WiFi stability and performance.
New features
- HDD Hibernation
- URL filter black/white list
- Bandwidth limiter on guest network
- URL filter support https website
Please unzip the firmware file first then check the MD5 code.
MD5: e46e8cfb5bd93116d91c2959e5e5f71f
Template
ASUS RT-AC3200 Firmware Version X (2018.xx.xx)
FW Download
X
X
X
Changelog
X
Thread starter | Title | Forum | Replies | Date |
L | Does the official firmware support SMBv2 now? | ASUSWRT - Official | 2 | |
K | ASUS WRT/Official Drivers & Merlin/WWDT for RT-AC65P/AX82U | ASUSWRT - Official | 11 | |
Auto Firmware Upgrade made official - a new Note in Asus FAQ | ASUSWRT - Official | 46 |
Welcome To SNBForums
