1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
RT-AC5300 and Flow Accelerator
Discussion in 'ASUS Wireless' started by Trik, Mar 13, 2018.
  1. Trik
    Trik New Around Here
    Mar 13, 2018
    5
    Hi all,
    Long time lurker, first time poster. I have been using Asuswrt-Merlin for a few years now, always been great (thanks for that!).
    Recently I moved to a new area with FIOS and 940/880 connection and I'm noticing that I am not getting anywhere near that speed. I usually top out just under 400Mbps.
    I was on the old 380 firmware, and have since updated to 384. Just to be safe, I did a full "Initialize" and reconfigured everything.
    I cannot get Flow Accelerator (FA) to enable, this is with a blank firmware, no special settings, everything disabled except for "Hardware Acceleration".
    The RT-AC5300 does support FA right? CTF is definitely enabled, but I can't get to level 2. I have all QoS disabled, no STP, no TrendMicro stuff... It didn't work in 380 or 384.4 Beta3.
    Any thoughts or troubleshooting steps? I've rebooted multiple times. Also, if CTF/FA Level 2 Hardware isn't what I should be using with a gigabit connection, (it seems in my research it is), also, let me know that!
    Thanks!!
  2. KevTech
    KevTech Very Senior Member
    Feb 27, 2012
    754
    United States
    You only need CTF for gigabit.
  3. Trik
    Mar 13, 2018
    5
    I appreciate that info, so then I should be seeing > 400Mbps via a wired connection since I do have CTF enabled. Running tests directly connected to the ONT, I see a much faster connection, so the bottleneck definitely seems to be the RT-AC5300.
    Still curious why I cannot get CTF/FA Level 2. In fact, with HW Acceleration disabled, I see slightly faster speeds (still not close to max), but of course the CPU utilization goes up considerably.
    Will the log in debug mode tell me why it isn't enabling Level 2?
  4. FeRReTTi
    FeRReTTi Occasional Visitor
    Apr 29, 2017
    15
    Hello,
    I have the same issue. I just updated to FIOS Gigabit speeds and am able to get those speeds if I directly connect to the Verizon modem but once I connect to the AC5300 with H/W acceleration off the quickest I get is ~400mbps. I am also unable to get CTF/FA level 2 and am interested in also finding a solution as I love this router and would definitely prefer to use it over the Verizon one.
  5. Trik
    Mar 13, 2018
    5
    Thanks for confirming you're having the same trouble FeRReTTi, I haven't found a solution, have you had any luck? I have reset, started from scratch and just tried to get CTF/FA Level 2, and haven't been able to. Have you ever seen this successfully enabled on an RT-AC5300 @RMerlin ?
  6. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    30,226
    Canada
    Flow Accelerator is not supported by SDK 7.14 devices (that means RT-AC88U, RT-AC3100 or RT-AC5300).
  7. Trik
    Mar 13, 2018
    5
    Oh that explains it then... thanks very much for confirming so I can stop thinking I’m doing something wrong.
    I guess next question is... CTF should be enough to pull gigabit speeds from the ONT, have you any suggestions? Should I just run with all HW acceleration disabled and let the CPU handle it?
    Thanks!!
  8. RMerlin
    Apr 14, 2012
    30,226
    Canada
    Should be enough, as long you don't start enabling features that will increase processing time, such as anything related to the Trend Micro engine. While the engine is compatible with CTF, it will still slow down traffic a bit.
    Also note that CTF will not work with port-forwarded traffic, as this needs to be marked for bypassing CTF.
  9. Find the Door
    Find the Door Senior Member
    Aug 2, 2013
    200
    Would the RT-AC86U be able to accommodate this? Also is the 86U supported by you?
  10. RMerlin
    Apr 14, 2012
    30,226
    Canada
    Hard to say without testing, since it will depend on what features you enable.
    Yes, the RT-AC86U is supported.
  11. doczenith1
    doczenith1 Very Senior Member
    Sep 19, 2014
    518
    MI
    I can confirm with my old 68U that FA would enable just fine with 380 and older branch firmware but it does not enable with 384 branch firmware. I get CTF only with 384. I can also confirm that my 68U would do 940 Mbps with only CTF so an AC5300 should have no problem.
