New Beta FW is available at the Asus website
I've actually not had any issues with the Smart Connect with all my 5GHz devices (mostly Apple but a couple of Windows).
In fact my experience so far is that Asus' implementation is much more effective than Netgear's more conservative implementation I've been used to.
Initially after update with this beta the UI was slow to respond but was fine after a power cycle.
Overall no major issues so far with this beta for me (and good to see some security fixes/issues addressed) although I've not tried MU-MIMO but then I've got no suitable clients.
Distributing them fine as far as I can tell (and the Asus UI makes this super simple to tell including the connection rate - I love this). Having said this I've not got any 5GHz capable N only devices - they're all AC, but the faster devices (like my 2015 MacBook Pro) consistently always get steered to the second 5GHz band and the other slower devices the first 5GHz band which I'm happy with. My experience is that Asus' implementation of SmartConnect is more effective than Netgear's somewhat more conservative and less tunable implementation.Are you sure your 5GHz clients are landing on the proper bands? 802.11n clients should be landing on 5GHz-1 and your 802.11ac clients clients should be landing on 5GHz-2. Double check in the GUI.
Welcome To SNBForums
