RT-AC5300 - Traffic monitoring via SNMP
orion44
I am using PRTG to monitor traffic on my RT-AC5300 running Merlin 380.64.
I am presented with following sensors and I'm not sure what they all are. I was able to piece some of together from this thread, but some still don't make sense.
(007) eth0 Traffic - WAN
(009) eth1 Traffic - Wifi 2.4G
(010) eth2 Traffic - Wifi 5G-1
(011) eth3 Traffic - Wifi 5G-2
(004) fwd0 Traffic - ??? (this appears to be traffic out from Wifi 5G-1 based on the usage)
(005) fwd1 Traffic - ???
(012) vlan1 Traffic - LAN switch
(013) vlan2 Traffic - ???
(014) br0 Traffic - Bridge (traffic doesn’t add up if it’s whole LAN)
Attached is screenshot of current usage as an example - Wifi 5G-1 is currently streaming ~3.5 MB/s which seems to be noted in fwd0 and not eth3
The fwd interfaces are something internal to Broadcom, and without access to their documentation, I'm not quite sure what these two contain. I believe they might be internal interfaces used between the wifi SoC and the CPU, but that's just a wild guess.
br0 is the LAN bridge, however it won't show traffic between LAN devices, as that traffic is switched, and isn't visible from the firmware's point of view.
