bbunge
Part of the Furniture
ASUS RT-AC66U B1 Firmware version 9.0.0.4.386.41994 (Beta Version)
Security Fixed:
Fixed CVE-2020-25681, CVE-2020-25682, CVE-2020-25683, CVE-2020-25687, CVE-2020-25684, CVE-2020-25685, CVE-2020-25686
Please be noted this is a quick fix beta version for DNSmasq vulnerabilities. Refer to "Method 2: Update Manually" in https://www.asus.com/support/FAQ/1008000 to update this firmware.
Note: as of this time the MD5 does not match. As with the AC68U Asus likely goofed and will have to update their web site. If you are concerned about the MD5 not matching you can download and install the beta firmware for the RT-AC68U on the RT-AC66U_B1.
Security Fixed:
RT-AC66U B1|WiFi Routers|ASUS USA
ASUS has a range of wireless routers suitable for every purpose. Whether it's for your home, for business trips, or for any other need or environment, there's an ASUS router for you.
www.asus.com
