I have a problem with my RT-AC66U. On firmwares higher than 380.57 router is working fine, until reboot or shutting down. After reboot it doesn't boots up, LEDs are blinking but Wi-Fi not working and router can't be reached via LAN connection. To make router boot up again, I need to turn it off, press and hold reset button and turn it on at the same time. After that I can access router's firmware restoration page, next step is Restore factory NVRAM settings and flash any firmware. After the firmware update process completes router successfully boots up and working fine but before next reboot
I've tried this firmware versions: 380.58_0, 380.59_0 and 380.61_0 and if one of them is installed I have a problem mentioned above. The last stable firmware version is 380.57_0, on this firmware and below I don't have such issues. I can reboot it or turn it off and it still working. The router is connected via an uninterruptible power supply. I'am rebooting router with reboot command via SSH. Maybe it is a hardware problem?
Please help me to resolve this issue.
P.S. Sorry for my bad English
