rt-ac66u: FF & IE can't access the adminpage
  • Thread starter Thread starter donbruno
  • Start date Start date
D
donbruno
Guest
Hello
I have the rt-ac66u and now there is a problem with loading the index.asp or other sites for administration. The announcement is no problem!
When I insert the IP 192.168.1.1 into the FF or the IE the adminstration page is so slow, sometimes it hangs :-( It's so frustrating!
Have anyone the same problems and a solution?
DOnBruno
solved
Hello
i have solved the Problem. The Problem was the antivir scanner AVAST. I turned off the antivirscanner and it goes :-) Now I hava a new antivir scanner and no problems.
Thx for the Help!
I have tried both, wireless and wired and nothing wound't work with AVAST.
DonBruno
