RT-AC66U not accessible anymore
guidoh
Hi guys, i hope you can help me. since several weeks i haven't been able to reach my router settings through the internet anymore. I haven't changed any settings and resets also don't help.
Anybody else having this issue or know how to solve this?
I'm running the 378.56 build.
How are you connecting? I had a problem with the secure shell when logging in after connecting to the OpenVPN server of router. I would type ssh username@192.XXX.XXX.XXX, and I would get no response asking for password. This fixed it in Linux, open terminal and run:
sudo ip li set mtu 1200 dev tun0
If your not using OpenVPN and have your router open to the Internet and you want to test my suggestion change tun0 to wlan0, eth0 etc. It worked for me, just for logging in via SSH, my AC68U web gui has always came up though.
I'm connecting through the DDNS service from Asus: xxx.asuscomm.com which used to work. Even if i use my WAN-adress instead of the DDNS i can't access so looks like ASUS service isn't to blaim.
