RT-AC66U router and two PCE-AC66 adapters - data transfer speed is low.
SickMind
Present: ASUS RT-AC66U router, two PCs equipped with PCE-AC66 wi-fi adapters, both connected to the router.
Scenario 1: one PC uses the 802.11ac WiFi connection (the PC can be either of the both present), the other PC uses the gigabit ethernet cable. Copy speed from one PC to another for one large videofile is 60 MB/sec. So it's ok.
Scenario 2: both PCs use the 802.11ac WiFi connection. Copy speed is 15-17 MB/sec for the same videofile. Data transfer speed dropped 4 times.
The videofile is the same, both PC are not moved around, 802.11ac connection speed is the same (as shown in Windows - 877 Mbit/sec), router settings are the same in both scenarios, firmware used - Merlin FW 3.0.0.4.374.33 Beta 1.
Question: How to increase the data exchange speed between the devices when they both use the 802.11ac WiFi connection (screnario 2)?
P.S. Sorry for my English, it's not native for me.
Nobody's tried to measure LAN to LAN connection speed with 802.11ac Wi-Fi?
Really?
The problem hasn't been solved still.
