templar4ik
Hi guys,
having trouble with this config:
- zyxel keenetic giga (192.168.1.1, 255.255.255.0) gets internet from WAN port, DHCP is ON
- asus rt-ac66u (192.168.1.101, 255.255.255.0) connected to zyxel via LAN-LAN ports, DHCP is OFF
my devices connected to asus wireless and by cable, LAN and internet is working great, all devices sees each other
problems started when i tried install entware
under ssh access, there is no DNS server and routing table looks like this:
i added nameserver 192.168.1.1 in empty resolv.conf
and default gateway
after this i'm having successfull ping
but entware setup script having timeout connect to wl500g-repo.googlecode.com
ping result
i found out that traceroute command failed on last chain everytime:
but from my workstation it's OK:
tried to reflash firmware, reset settings to default, nothing's work...
firmware is 3.0.0.4.374.35_4 (Merlin build)
192.168.1.0/24 dev br0 proto kernel scope link src 192.168.1.101
127.0.0.0/8 dev lo scope link
and default gateway
ip route add default via 192.168.1.1
--- google.com ping statistics ---
13 packets transmitted, 13 packets received, 0% packet loss
round-trip min/avg/max = 1.062/1.178/1.535 ms
ping result
PING wl500g-repo.googlecode.com (173.194.71.82): 56 data bytes
64 bytes from 173.194.71.82: seq=0 ttl=50 time=34.899 ms
64 bytes from 173.194.71.82: seq=1 ttl=50 time=34.516 ms
64 bytes from 173.194.71.82: seq=2 ttl=50 time=34.567 ms
64 bytes from 173.194.71.82: seq=3 ttl=50 time=34.551 ms
64 bytes from 173.194.71.82: seq=4 ttl=50 time=34.832 ms
64 bytes from 173.194.71.82: seq=5 ttl=50 time=34.577 ms
64 bytes from 173.194.71.82: seq=6 ttl=50 time=34.548 ms
64 bytes from 173.194.71.82: seq=7 ttl=50 time=34.511 ms
64 bytes from 173.194.71.82: seq=8 ttl=50 time=34.589 ms
64 bytes from 173.194.71.82: seq=9 ttl=50 time=34.614 ms
--- wl500g-repo.googlecode.com ping statistics ---
10 packets transmitted, 10 packets received, 0% packet loss
round-trip min/avg/max = 34.511/34.620/34.899 ms
traceroute to google.com (188.43.64.102), 30 hops max, 38 byte packets
1 KEENETIC_GIGA (192.168.1.1) 0.519 ms 0.452 ms 0.407 ms
2 109.124.192.1 (109.124.192.1) 0.718 ms 0.806 ms 0.728 ms
3 p161-73.samaralan.ru (85.236.161.73) 0.956 ms 0.939 ms 0.931 ms
4 105.128.76.80.tetra.samara.ru (80.76.128.105) 1.059 ms 1.089 ms 0.986 ms
5 SMA15.transtelecom.net (217.150.38.146) 1.187 ms 1.438 ms 1.162 ms
6 * * *
7 * * *
8 * * *
Трассировка маршрута к google.com [188.43.64.95]
с максимальным числом прыжков 30:
1 <1 мс <1 мс <1 мс KEENETIC_GIGA [192.168.1.1]
2 1 ms 1 ms <1 мс 109.124.192.1
3 1 ms 1 ms <1 мс p161-73.samaralan.ru [85.236.161.73]
4 1 ms 1 ms 1 ms 105.128.76.80.tetra.samara.ru [80.76.128.105]
5 1 ms 1 ms 1 ms SMA15.transtelecom.net [217.150.38.146]
6 1 ms 1 ms 1 ms 188.43.64.95
Трассировка завершена.
