RT-AC66U Statis routing?
TWAD
RT-AC66U Static routing?
Hey All,
Has anybody been successful creating static routes with the RT-AC66U? If you have will you help me through this issue?
My configuration
I have my AC66U on NetA: 10.10.1.0/24
I have <multiple wireless routers tried> on NetB: 192.168.1.0/24
Here is my issue:
I cannot communicatate between both networks from NetA.
I want bi-directional NetA (LAN) connectivity to NetB (WAN)
I attempt to set up a static rout from NetA to NetB in the AC66U UI and apply the added routes, but the routes do not show up in the UI system log routing table, or via telnet and command-line “route”.
I then manually set the route via telnet and command-line and the routes show up in the UI Routing Table. However, the routes do not work as follows:
I can ping from NetB to 10.10.1.0/24, but not reverse. I have set every NetB WAN interface to no firewall, and have tested them directly, but I cannot route from a host in NetA to even the router Interface on NetB.
Has anybody else had success here?
Thank you
