Rt-ac68r bootloader question
Pierino
I just picked this unit up on eBay. The bootloader is 1.0.1.1.
I upgraded the bootloader on my rt-ac68u using the utility but I'm wondering if I should on this.
Would leaving it as is make it more attractive to a future buyer? So they can use the overclock function?
I suggest you update to 1.0.1.6 as you can still overclock using NVRAM values which does the exact same thing as the currently broken "Turbo Mode" which I can only assume will be fixed in the future (possibly the next major release)
