[RT-AC68U] [3.0.0.4.380_1842] CTF disabled will disable wireless access.
fireplace
I have a stock [RT-AC68U] with FW version [3.0.0.4.380_1842], which the GUI says it up-to-date. I wanted to make the stats correct, so I tried disabling CTF. When CTF is disabled, my wireless clients can connect to the router, but cannot access the internet. Is this a known issue? Is there something else that should be done? I've tried rebooting.
--FP
Yes, and it's been fixed weeks ago with the 2695 release.
That's good to know, but brings a second question. When I click on the "Firmware Version" Check button it says that I have the latest. Are newer versions not picked up immediately? Should I wait and do it the easy way with the GUI or will I have to manually download it?
--FP
