af32d
Hi guys,
Last week I've updated my Asus RT-AC68U to the newest firmware 384.4. I'm not sure what went wrong, but since that time I'm having real strange connectivity issues.
- Visiting a webserver on my LAN results in endless loading, until I start a ping command to the same IP, then the request is delivered to my browser immediately.
- My MySQL server (LAN) generates errors that acces is not allow from 10.0.0.1 (this is the Router's IP, not the client that is trying the connection)
- nslookup's towards my self hosted DNS server (LAN) also generate errors that looks like this: ";; reply from unexpected source: 10.0.0.1#53, expected 10.0.0.10#53". My DNS server is hosted on 10.0.0.10, the router is hosted on 10.0.0.1.
- Some devices on the LAN loose connectivity (virtual unix servers) towards each other over time. Also my Sonos is having a hard time.
I've never seen those issues before, and it looks to me like the router is changing the source address of packages to it's own address. This is causing a lot of issues.
After updating to 384.4, I've performed a factory reset and reconfigured the settings. Since I've discovered the issues mentioned above, i've tried to:
- Reinstall 384.4, with factory reset and without any other changes than changing the router IP to 10.0.0.1 (DHCP changes automatically to the same range).
- Downgrade to the 380.x version that used to work perfectly, with factory reset
- Upgrade to 384.4 again, with factory reset.
None of those solutions worked, and I'm stuck with a buggy network now. I'm not sure what else I could try to debug/solve this issue. Or if it's a bug in 384.4.
Thanks,
Thanks,
