BlackMage
firmware version: 380.65_beta1 (i am not sure from which version this error occurs)
in the menu 'USB application' i can´t install the 'Download Master' permanent, after every reboot is the 'Download Master' entry disappeared
when i have the 'Download Master' installed, the entry and the information is shown (until the next reboot, then the "Download Master" installation will be forgotten, but I can call it anyway)
After every reboot I can reinstall the 'Download Manager'!
i have in the Administration under 'System' -> 'Persistent JFFS2 partition' the entry 'Format JFFS partition at next boot' set to the point 'No' and the entry 'Enable JFFS custom scripts and configs' set to the point 'Yes'.
