Hello
Let me give some feedback.
I decided not to bloat my AC68U router and tested this on my old RT-AC66U.
Installed Merlin, then had big issues installing ntware and amtm.
Created a swap partition on a USB stick on my Windows then after lots of headaches managed to install amtm.
Then transmission packages had different names and had issues with that too, but managed to install it too.
Got things running and tested and all worked.
Found an extension for Firefox that works perfectly too:
Download Torrent Control for Firefox. Send torrent and magnet links to your Bittorrent client's web interface. Supports BiglyBT, Cloud Torrent, Deluge, Flood, ruTorrent, Tixati, Transmission, tTorrent, µTorrent, Vuze and qBittorrent.
addons.mozilla.org
It can download from the sites that Download Master could not.
The speed seems ok and saw 7-8 Mb/s download.
Unfortunately, Transmission seems rather heavy even though they advertise it as lightweight. The CPU was constantly at 100% while downloading. I know that RT-AC66U is not as powerful as the RT-AC68U, but it is a bit concerning.
I do not know if I should waste time installing it on the AC68U.
Saw some threads about performance here:
Hello, I'm using Latest stable merlin release ( 3.0.0.4.374.39 ) on a RT-AC66U, and I've installed entware and trasmission: recently I've noticed that trasmission daemon started to cause very hight cpu load. I've tried to reset the router and reinstall everything, but with no luck. 950...
www.snbforums.com
Hi does anyone have a Idea why when I download a torrent and it reaches 50 to 60mbps (60mbps is my connection speed) the AC87U cpu shows nearly 100 percent core 1 and about 50 percent core 2, the less the speed less CPU load, net is enabled , when I try speedtest.net and get 60mbps CPU stays...
www.snbforums.com
You said that you tested on the same router, did you check the CPU load? If you still have that set up, could you please post your memory and CPU load?
Thank you.
