RT-AC68U entware lost when I added another USB quick help
pp5858
Hi, so installed on USB2 /dev/sda1 entware at location /tmp/mnt/sda1 I think
Now when I added USB3 device for media, entware and others are lost as that came /dev/sda1 and /dev/sda2 device and USB2 entware swithced to /dev/sdb1 and /tmp/mnt/sdb1
I think bc. of that it is lost.
Is there somewhere jffs or GUI location or how should I correct this, I could not find fstab or so to fix?
First, reboot the router to see of the Entware is fixed. If not look at the scripts (/jffs/scripts) that start Entware and change sda to sdb
It did not came back with reboot. Nor even when I removed the USB3 drive.
There is only post-mount and services-stop under scripts. post-mount has
/jffs/addons/diversion/mount-entware.div
and that does not have sda sdb on it. So it seems that it is in links, have to look them what is messed
Do not change anything in the scripts under /jffs/addons or /jffs/scripts that were created by amtm or Diversion. They work, I‘m sure of it.
Rather, look for relevant messages in the routers (WebUI) Syslog page after a reboot. It will tell you why it failed to start Entware.
