DualPlatform
History: My in-laws purchased (on my direction) a TMobile branded Asus AC1900 so that I could flash it into a true RT-AC68U. I have previously done this 2 times before with no issues. Unfortunately the return period elapsed before I could get my hands on the unit and test it out only to find that the wifi was little to non-existent. This didn't matter if the unit was on the original TMobile firmware, ASUS proper, or Merlin (my preferred fw).
You must be within 1ft of the router before you can detect a signal and even then you may see 1 or 2 bars on a typical device. Using a standard wifi-scanner app on a smart phone the signal is dwarfed by my neighbors from across the street when I'm in the same room as the unit.
All other functions on the router work just fine, just the wifi that's bad.
Things that have been tried thus far:
1. The unit has been flashed numerous times. Additionally I've tried a power boosted CFE as well as making sure the wifi power settings when using Merlin were cranked as high as I could get them.
2. I have also tried other antenna on the device, those from other known working ASUS routers and nothing changes
3. I've opened the unit thinking there might be some bad solder points on the antenna connectors. I haven't hit them with my soldering iron yet but that may be my next move.
I've dug through the forums and general internet not finding much regarding this issue. It leads me to believe that the unit is just bad and nothing can be done. I don't like giving up so I'm posting here as a last effort to get this RT-AC68U working.
Any other suggestions would be very much appreciated. If nothing else I'll use this as a wired only router for my in-laws and get them another AP.
Thanks!
-Kirk
Thanks!
-Kirk
