RT-AC68U problem with telnet
hispanico957
I have last firmware 380.62_1 and i have this router form 10 days and form ten days (before i have dir-655 d-link) i have problem with telnet installed on my windows 10.
I try to connect and run well...after some time i open telent windows and
or
So why this ? there some settings to unable, repeat before with onother router never have this problem.
Thank
Hispa
or
Thank
Hispa
have you enabled telnet in the asus gui ?
its under the administration tab on the gui of the asus
or are you saying telnet works initially then stops working ?
pete
What is the device at 192.168.0.195? Is it the RT-AC68U? Why is it not 192.168.1.1?
Have you turned on telnet access on the router? Administration > System > Enable Telnet
The default network for the dir-655 is 192.168.0.x
The default network for the Asus is 192.168.1.x
Have you changed the network on the Asus? If you haven't then that is your problem.
Can you ping it?
ping 192.168.0.195
