RT-AC68U Rclone
yop16
Hello, sorry for my english, I can intall Rclone with
Objective-C:
opkg install rclone
But is imposible to open the rclone config
anywere can help me?
Have a look here;
It may be that you need to specify a location for the config file.
Did a few more little searches. What router are you using? Seems that some routers may not be able to run rclone (kernel 2.6). Did also find this, don't know if it will be of any help, but I offer it anyway;
Works fine for me yop16 with RTAX86U - you just have to specify config file on the USB with "--config".
I even made a funky script to monitor a directory for creation of a PDF (sent by my scanner over samba share) and, upon detection of a new PDF, upload it to OneDrive, as follows:
#!/bin/bash
log_file="/mnt/-/upload-scans-log.txt"
rclone_config_file="/mnt/-/rclone_config"
scans_dir="/mnt/-/shares/Scanned Documents/"
upload_dir="OneDrive:/Scanned Documents/"
while [[ true ]]; do
        if ! rclone --config "$rclone_config_file"  move "$scans_dir" "$upload_dir" --include "*.pdf" 2>&1 >>"$log_file"; then
                break
        fi
        if ! inotifywait -r -e modify,create,move --include "\.pdf" --format '%T %:e %f' --timefmt '%c' "$scans_dir"  2>&1 >>"$log_file"; then
                break
        fi
done
This requires 'inotifywait' to be install using opkg.
