RT-AC68U recurring packet errors in history
jacrouter
I get multiple errors in history similar to the one above:
Dec 2 15:13:32 lld2d[459]: packetio_recv_handler: g_opcode 8 with seq=22106 (from realsrc=f0:82:61:e1:f8:5a) is illegal; dropping
realsrc being the Internet provider box to which RT AC68 is linked by a cable ethernet connection.
Can anybody help me understand what this error means and how to spot and correct the problem?
XabiX
Hi guys,
Anyone knows? as I have the same and couldn't find explanation on google:
  1. Oct 26 08:25:21 lld2d[507]: packetio_recv_handler: g_opcode 8 with seq=54602 (from realsrc=48:83:c7:38:0d:60) is illegal; dropping
My concern to see these lines when I am behind a Service Provider ADSL box (Orange Livebox Play) which should normally block incoming packets so normally my Asus router should not receive those as he is not set as a DMZ and neither with port forwarding.
  1. Oct 26 08:28:20 kernel: DROP IN=eth0 OUT= MAC=1c:b7:2c:c2:0d:b0:48:83:c7:38:0d:60:08:00 SRC=5.101.7.147 DST=192.168.1.2 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=11853 PROTO=TCP SPT=56962 DPT=3701 SEQ=260968280 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
  2. Oct 26 08:28:22 kernel: DROP IN=eth0 OUT= MAC=1c:b7:2c:c2:0d:b0:48:83:c7:38:0d:60:08:00 SRC=5.101.7.147 DST=192.168.1.2 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=35918 PROTO=TCP SPT=56962 DPT=3986 SEQ=1956424892 ACK=0 WINDOW=1024 RES=0x00 SYN URGP=0
Is there a parameter to harden the security in the router?
Merci
XabiX
XabiX
I am wondering if this post is on the right section :) (if not can an admin move it?)
THANKS and good WE
ivi
Hi jacrouter
I have the same Problem with my RT-AC88U.
Therefor, did you solve the Problem?
Thank you for your help!
Greetings ivi
ivi
Hi to everybody
Please for help.
I have a RT-AC88U behind a cable moden as a AP.
Feb 10 15:54:22 lld2d[307]: packetio_recv_handler: g_opcode 8 with seq=19992 (from realsrc=b4:ee:b4:76:7e:95) is illegal; dropping
realsrc being the Internet provider box to which RT AC88U is linked by a cable ethernet connection. (swisscom)
Can anybody help me understand what this error means and how to correct the problem?
Thank you for reading and helping!
Greetings ivi
