RT-AC68U with BT FTTP
bapesta786
Hi there - I just had BT FTTP installed yesterday and was wondering if anyone has had any success in getting the AC68U working with full speed on the 900/110 package? Any special settings you used? I have disabled QoS and enabled NAT acceleration.
I am on Merlin FW 384.15 (old yes i know but it's kept working so I've not touched it) but I am tempted to do a factory reset and install the latest Merlin FW.
Also - from within the router - how do I see what speed I am connected at? I can't find it anywhere!
First, flash the latest firmware on the router.
Download | Asuswrt-Merlin
Then, perform a full reset via the WPS button and configure the router manually (and minimally).
The following links may help you get the router up-to-date and to a good/known state if the overview above isn't enough.
Fully Reset Router and Network
Best Practice Update/Setup Router/AiMesh Node(s) 2021
Do not use saved backup config files.
Do not plug in any USB devices before verifying that the router/network is working as expected after the upgrade.
About L&LD
S Vodafone FTTP VLAN Routers 1
