RT-AC68U
JustAnotherUser
I have two RT-AC68U routers - one a standard ASUS model, and one was a T-mobile router until I flashed it to Merlin. One is the main router and connection to the cable modem. The second is a repeater that serves our smart TV over WiFi (2.4ghz), it connects to the main router over 5ghz. Working for weeks with 380.64_2, upon upgrading the 380.65 the repeater would only hold connection for a couple minutes then freeze, requiring a reboot. Downgrade both the 380.64_2 and it again works fine.
What information do you need to help find the problem?
Maybe a simple factory reset and manual re-config could help... :rolleyes:
...should not be a big deal on the repeater!
