I have upgraded AC-RT68U to AC-RT86U and I have a problem with my temperature and humidity sensors (based on ESP8266). I have read a lot of topics about problem with ESP8266, but I think my is different. My nodes are reading temperature and humidity once per 5 minutes and are sending to my server in my LAN. After sending measurements the are going to sleep for 5 minutes (so, they are going to disconnect from WLAN). Some times they working couple of hours, sometimes couple of minutes. I think they have problem with obtain IP adress from DHCP. Below I present log when they dont work:
and when they work:
To fix the problem I have to do one of these things:
- turn off/on 2.4GHz radio,
- connect to 2.4GHz network form my laptop (very weird),
- restart router.
I have disabled beamforming, MU-MIMO and etc. (I have read about Tasmota and ESP8266 problems). I attached my configuration of 2.4GHz WLAN. The same problem persist on the last stable Merlin (386.1_2 ) and Asus stock firmware.
I think, that the problem is not related with signal strength (RSSI of sensors is between -60 and -80dBm) and is not related with their firmware (they worked with no problem since september). In logs I didn’t find anything usefull…
Thank you for any help and suggestions.
Mar 18 16:47:20 dnsmasq-dhcp[1937]: DHCPDISCOVER(br0) a4:cf:12:f5:28:6a
Mar 18 16:47:20 dnsmasq-dhcp[1937]: DHCPOFFER(br0) 10.10.10.14 a4:cf:12:f5:28:6a
Mar 18 16:47:30 dnsmasq-dhcp[1937]: DHCPDISCOVER(br0) a4:cf:12:f5:28:6a
Mar 18 16:47:30 dnsmasq-dhcp[1937]: DHCPOFFER(br0) 10.10.10.14 a4:cf:12:f5:28:6a
Mar 18 16:47:54 dnsmasq-dhcp[1937]: DHCPDISCOVER(br0) a4:cf:12:f5:28:6a
Mar 18 16:47:54 dnsmasq-dhcp[1937]: DHCPOFFER(br0) 10.10.10.14 a4:cf:12:f5:28:6a
Mar 18 16:48:16 wlceventd: wlceventd_proc_event(507): eth5: Disassoc A4:CF:12:F5:28:6A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar 18 16:48:16 wlceventd: wlceventd_proc_event(490): eth5: Deauth_ind A4:CF:12:F5:28:6A, status: 0, reason: Class 2 frame received from nonauthenticated station (6), rssi:0
and when they work:
Mar 18 17:58:37 dnsmasq-dhcp[20736]: DHCPDISCOVER(br0) a4:cf:12:f5:28:6a
Mar 18 17:58:37 dnsmasq-dhcp[20736]: DHCPOFFER(br0) 10.10.10.14 a4:cf:12:f5:28:6a
Mar 18 17:58:37 dnsmasq-dhcp[20736]: DHCPREQUEST(br0) 10.10.10.14 a4:cf:12:f5:28:6a
Mar 18 17:58:37 dnsmasq-dhcp[20736]: DHCPACK(br0) 10.10.10.14 a4:cf:12:f5:28:6a ESP-F5286A
Mar 18 17:58:38 wlceventd: wlceventd_proc_event(507): eth5: Disassoc A4:CF:12:F5:28:6A, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar 18 17:58:38 wlceventd: wlceventd_proc_event(490): eth5: Deauth_ind A4:CF:12:F5:28:6A, status: 0, reason: Class 2 frame received from nonauthenticated station (6), rssi:0
- restart router.
