RT-AC86U cannot entware
yhq_34
Hi, I have found RT-AC86U stock firmware cannot install entware, there was opt folder exist.
So no other ways to install entware except change to merlin firmware?
I'm with the latest Merlin but I have this issue with the installation "entware-setup.sh"
ASUSWRT-Merlin RT-AC86U 384.11-2 Sat May 18 03:35:09 UTC 2019
miazza@RT-AC86U-3150:/tmp/home/root# entware-setup.sh
Info: This script will guide you through the Entware installation.
Info: Script modifies "entware" folder only on the chosen drive,
Info: no other data will be changed. Existing installation will be
Info: replaced with this one. Also some start scripts will be installed,
Info: the old ones will be saved on Entware partition with name
Info: like /tmp/mnt/sda1/jffs_scripts_backup.tgz
Info: This platform supports both 64bit and 32bit Entware installations.
Info: 64bit support is recommended, but 32bit support may be required
Info: if you are using other 32bit applications.
Info: The 64bit installation is also better optimized for newer kernels.
=> Do you wish to install the 64bit version? (y/n) y
Info: Installing the 64bit version.
Info: Looking for available partitions...
*** Error: No ext2|ext3|ext4 partitions available. Exiting...
What shall I do ?
What shall I do ?
Do what the error message is telling you. Insert a USB disk and create at least 1 partition that is formatted as ext2, ext3 or ext4. There is a utility called amtm here that has a "format disk" option that will do that for you.
