RT-AC86U --> Spectrum
ApexRon
Sometimes it helps to see a working WAN configuration for a specific ISP and I thought I would share.
It would be nice if you shared something more readable. I can barely see your settings with 4 pixels high text.
+1 same settings but with DNS frequency set to aggressive (by default) and Rebind protection on, 9.9.9.9 as WAN dns, + 9.9.9.9 dns privacy default. But I enabled get dns from ISP on power cycle on firmware update just because I am behind CG-Nat.
Edit : ISP dns frequency
I will add the PDF
  • RT-AC86U - Spectrum.pdf
Is your ISP Spectrum?
