RT-AC86U VLAN TAG
viktor.colap
I use Asus RT-AX86U on my network, but I use it not as a router, but as a switch. That is, two tagged vlans (100,200) come to LAN1 and I need clients, when connecting to wi-fi, to gain access to vlan 200. And I, as an administrator, connecting with a cable to the LAN2 port have access to vlan100.
If the web interface had such an option, I would set it up myself. But after reading several articles on the forum, I saw that they use the vlanconfig utility, but in most cases it is applicable to wan, but I don’t use wan. I ask for help in setting up the router.
Merilin firmware installed
