RT-AC87U + 380.63_2 + Reboot
Since few times my Router reboot alone.
Why ?
My RT-AC87U is running just fine. No issues and no reboots.
I have only
Nov 30 20:52:36 ALERT MAIL: AiProtection send mail
Nov 30 20:53:02 kernel: ACCEPT IN=eth0 OUT=br0 SRC=myhiddenip DST=192.168.1.111 LEN=64 TOS=0x00 PREC=0x00 TTL=61 ID=7130 DF PROTO=TCP SPT=49208 DPT=5501 SEQ=819823750 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (020405B4010303050101080A14CFE02B0000000004020000)
Aug 1 02:00:11 syslogd started: BusyBox v1.20.2
Why ?
my 87u is rebooted too with latest rmerlin fw. i back to 9460.
try disable Traffic Analyzer or other AIProtection features if enabled.
Rt-ac87u RMerlin 38.63.2 uptime 2 days 1 hours 30 minute(s) 26 seconds
87U, 63_2 here; uptime 13 days 15 minutes.
different enviroment, different config.
I have the same router and the latest RMerlin firmware. Unless you are using the new preview builds.
Hi guys,
I had the same issue. I saw one post in another thread saying that by switching off mail notifications in AiProtection it was not rebooting anymore (which seems to match the message in your log before the reboot by the way).
I tried it and it is working like a charm... My router has been up for over 330 hours now without any issue. I was using google mail as a recipient and I will try with another provider as soon as I have the time.
Maybe you should give this a try.
Best
