RT-AC87U or RT-AC68U?
JokerPower
Hello
I need a new router, especially for WiFi signal coverage and speed. RT-AC87U is for 200 euro, while RT-AC68U is about 160 euro. They are different categories, AC2400 vs AC1900. All my devices are N. Is it worth buying 87U? Or better stick with 68U?
68U! AC87 is over kill and 4x4 not even enabled on it yet. AC1900 is stable and in it's prime. AC2400 still in beta phase.
For that price difference, I would also suggest the RT-AC68U.
You may want to try it with hggomes firmware fork too, PM him for the links.
68U hands down - stable and mature... and fast...
Unfortunately standing design rules this out for me...
Is AC87U indeed so bad, so it should be avoided?
As I have multiple AC draft devices now (Most are 2x2, one is even 3x3), looking for something to replace my trusty old N66U...
It's not that the 87U is bad, but that the 68U is so darn good for an Asus router- most of the kinks on that device have been worked out...
Read thru the threads, most of the issues with the 87U are basic stuff, not esoteric items that we're seeing with other devices... don't get me wrong, Asus is working hard to improve the stability there, and have made good progress...
Tiger Direct Insiders the AC87U is now $199.99 till midnight tonight.
I see the Asus RT-AC87U at Tiger Direct for $179.99 (free shipping, too), which includes a rebate from McAfee. The only bad part of that is having to dispose of the McAfee crap after getting the package. Unless its just a download. The other thing is that I hate applying for rebates, usually miss some detail and either don't get the rebate or have to do it over *smile*. And they take forever to get, if you do get them. So I don't buy things based on rebates...
If you're okay with rebates, here you go *smile*:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=9567072&CatId=373
That's after the rebate if I am correct. I wouldn't buy any 4x4 router at this time anyway.
Well, I have actually read those threads, and got a pretty good picture...
Apparently I have to go for a non-Asus this time, as there is absolutely no way I can fit AC68U to my AV rack, it is just too high and there is absolutely no way to put it horizontally...
I don't see any benefit of buying AC66U as it costs pretty much the same here, as AC68U and has only minor improvements over N66U...
I can only speak for myself but in my house, the AC68U (as well as the R7000 and WRT1900AC) was a quite dramatic improvement of the N66U in terms of both throughput and range.
I made a typo, what I actually wanted to say is that AC66U has only minor improvements over N66U, it only has different 5Ghz radio, but costs about the same as AC68U...at least here...
AC66U is approx 150€, and AC68U is 165€...
Came into conclusion that no feasible alternative exists to AC68U, so...still bought it and found another feasible location for it... :D
The r7000 has a faster cpu and runs cooler, the ac68 had a tad better range in my setup. Subjective. For the price difference get the ac 68, put Merlin wrt on it and enjoy! If you want VPN performance and need a fast CPU than the R7000 is a better option.
Sent using Tapatalk
Wireless range is highly influenced by location and environmental factors. In my house, the R7000 outperforms the AC68U on both bands, and quite significantly on the 2.4Ghz band. In fact, the R7000 and WRT1900AC can cover my whole house by themselves and the AC68U cannot.
R7000 or WRT1900AC?
I use the WRT1900AC. In my house, the Netgear R7000 has excellent coverage in some areas, good in some, and poor in others. The WRT1900AC is much more consistent - there's not as many "excellent" areas compared to the R7000 but there are zero "poor" areas.
R7000 or WRT1900AC?
I'd pick R7000, lots of alternative firmware (3 different strong contenders available now), solid wireless, great piece of hardware. Latest did-wrt with R7000 is really great. On the other hand, the WRT1900AC is good, too. However, I wouldn't want to be limited to Linksys stock firmware. Kong is working on dd-wrt firmware for it, but it isn't generally available yet. You know what they say about buying something based on promises about the future...not a good idea.
Hi Roger, I see from your sig you have both the ac68p and R7000, which do you find has better performance? I am thinking on getting the R7000 as there is now a version of Merlins fw available for it, have you tried it? I cant get the P version of ASUS where I am.
