[RT-AC87U] Wireless printing fails for no particular reason
got_milk
I've been wrangling for this one for a few days with little success.
I replaced an old RT-N66U with an RT-AC87U, which I'm very happy with the upgrade. It came with an odd side-effect, however: my HP wireless printer has decided to intermittently stop working. Here's the scenario:
HP Printer <---- 2.4GHz ----> RT-AC87U <---- 5GHz ----> MacBook Pro
The first time I tried to print from this setup it didn't work, displaying a connection error with the printer. I was able to reestablish connection with the printer by removing it from the MacBook Pro and reinstalling it - I was able to print and scan for a few hours afterwards. After that, however, the printer became unresponsive again. On certain occasions if I leave the job in the print queue, it will suddenly spring to life and print it minutes or even hours later, work fine for a period of time (normally a couple of hours), then resume being unresponsive.
If I remove the printer from the MacBook Pro and reinstall it, it will always work for a number of hours and then resume intermittent failures.
When the printer is "not connected", it does respond to pings normally from the affected MacBook Pro.
If I swap out the RT-AC87U for the old RT-N66U, the printer works reliably without issue again.
Does anyone have any ideas what is causing this and how I can fix it?
I would try to do a factory default reset of the printer, in case it still stored some low-level wireless information that were specific to the previous router.
Tried that yesterday, as well as clearing the printing system on OS X. Same issue cropped up today.
Did that as well - printer is running both the latest firmware and accompanying driver on OS X.
I did update to Merlin's new .50 beta 1 firmware and things have improved greatly - the printer does seem to respond much faster, especially when querying for ink levels (what took ~10 seconds before takes less than a second on Merlin's build) so fingers crossed that the connection holds up over time.
