RT-AC88U Can it use multiple wan static ip addresses?
pelfed
Greetings.
I have the AC88U router ( currently on the default firmware ).
I would like to be able to set up the router to allow multi Wan ( similar to Draytek ) as I have 8 static wan IP addresses available from my provider.
Is this possible with the wrt-merlin firmware?
sbsnb
You want to have 8 WAN connections to an RT-AC88U, or you want to assign static addresses from your ISP to the RT-AC88U's clients?
pelfed
Hi - I would like to assign isp static addresses to certain clients if possible.
sbsnb
You should be able to do it through the web UI on LAN -> DHCP Server -> Manually Assigned IP around the DHCP list.
I've never tried to assign publicly routable IPs there, so let us know if you have trouble. I suspect even if it works it won't work the way you expect as the router will still be performing NAT, but it's worth a try.
ColinTaylor
Part of the Furniture
No, the firmware does not support this sort of configuration.
Jeffrey Young
I don't have the AC88U, so I don't know if this will work, but I use the following method to pick up a second IP from my provider if I am testing a new router or other internet equipment and need an ISP provided address.
Log into the router, then
LAN->IPTV
Then in "Choose IPTV STB Port", select which LAN port to use. Hit apply. Once the router reboots, any equipment plugged into that LAN port gets a IP direct from my ISP. In my case, my ISP uses DHCP. Not sure if this will work with a static IP assignment. You may have to do some additional scripting to bring up the interface with a set IP (Merlin stuff).
sbsnb
Might be able to configure the devices themselves with a static IP and route everything on the 88U straight through to those IPs.
ColinTaylor
Without being able to configure his multiple IP addresses on his WAN interface no internet traffic (for those extra addresses) is ever going to reach the router. That's not possible with stock Asus firmware. He might be able to script it in Merlin and then create some 1:1 NAT rules. I think there was another thread asking about this recently.
EDIT: Have a look at this. It could probably be adapted for Merlin. https://wiki.dd-wrt.com/wiki/index.php/One-to-one_NAT
