RT-AC88U drop packets, slow wired speeds
SystemF
Recently I've change my ISP. Now I'n on FTTB, the switch witch belong to the ISP is in the basement huawei with 8 10/100 ports, from there cat5e cable to my Asus rt-ac88u.
I've experience wired packets drops, on speedtest.net, high latency about 10-15ms + and about 6-7 Mbps slow download on torrents, tested with the router given by my ISP(10/100 ports), no problem get full speed, tested with dual wan, same results, tested with cable directed to the pc, bypass the router, everything is fine, firewall off, dos protection on router same result.
From what I've read , or negotiation issue or its faulty unit imho ?
