RT-ac88u firmware 384.14.2
tc001mt
Hello, yesterday i installed firmware version 384.14.2 everything works good but if i connect to front USB (3.0) one HD something happen to 2.4ghz network.
Everything connected to 2.4Ghz disconnect. Disk and 5Ghz works.
And logs begin to register messages like this:
Jan 21 15:33:30 syslog: WLCEVENTD wlceventd_proc_event(420): eth1: Auth XX:XX:XX:XX:XX:XX, status: 0, reason: d11 RC reserved (0)
Jan 21 15:30:48 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
Jan 21 15:30:48 kernel: xhci_hcd 0000:00:0c.0: WARN: short transfer on control ep
Jan 21 15:30:48 kernel: xhci_hcd 0000:00:0c.0: disable burst on ep 2
Jan 21 15:30:48 kernel: xhci_hcd 0000:00:0c.0: WARN no SS endpoint bMaxBurst
Jan 21 15:30:48 kernel: scsi2 : usb-storage 1-1:1.0
Jan 21 15:30:49 kernel: scsi 2:0:0:0: Direct-Access SABRENT 0204 PQ: 0 ANSI: 6
Jan 21 15:30:49 kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
Jan 21 15:30:49 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jan 21 15:30:50 kernel: sd 2:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
Jan 21 15:30:50 kernel: xhci_hcd 0000:00:0c.0: WARN: Stalled endpoint
Jan 21 15:30:50 kernel: sd 2:0:0:0: [sda] Write Protect is off
Jan 21 15:30:50 kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
Jan 21 15:30:50 kernel: sda: unknown partition table
Jan 21 15:30:50 kernel: sd 2:0:0:0: [sda] Attached SCSI disk
Jan 21 15:30:51 kernel: tntfs info (device sda, pid 6178): ntfs_fill_super(): fail_safe is enabled.
Jan 21 15:30:51 kernel: tntfs info (device sda, pid 6178): load_system_files(): NTFS volume name 'USB3', version 3.1 (cluster_size 4096, PAGE_SIZE 4096).
Jan 21 15:30:51 hotplug[6171]: USB ntfs fs at /dev/sda mounted on /tmp/mnt/USB3
Jan 21 15:30:51 usb: USB ntfs fs at /dev/sda mounted on /tmp/mnt/USB3.
Jan 21 15:30:51 rc_service: hotplug 6171:notify_rc restart_nasapps
Jan 21 15:30:51 avahi-daemon[3598]: Files changed, reloading.
Jan 21 15:30:51 avahi-daemon[3598]: Loading service file /tmp/avahi/services/mt-daap.service.
Jan 21 15:30:51 iTunes: daemon is stopped
Jan 21 15:30:51 FTP_Server: daemon is stopped
Jan 21 15:30:52 Samba_Server: smb daemon is stopped
Jan 21 15:30:52 kernel: gro disabled
Jan 21 15:30:52 avahi-daemon[3598]: Got SIGTERM, quitting.
Jan 21 15:30:52 avahi-daemon[3598]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.1.
Jan 21 15:30:52 avahi-daemon[3598]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Jan 21 15:30:52 avahi-daemon[3598]: avahi-daemon 0.7 exiting.
Jan 21 15:30:52 Timemachine: daemon is stopped
Jan 21 15:30:52 miniupnpd[3585]: shutting down MiniUPnPd
Jan 21 15:30:52 kernel: gro enabled with interval 2
Jan 21 15:30:52 avahi-daemon[6205]: Found user 'nobody' (UID 65534) and group 'nobody' (GID 65534).
Jan 21 15:30:52 avahi-daemon[6205]: Successfully dropped root privileges.
Jan 21 15:30:52 avahi-daemon[6205]: avahi-daemon 0.7 starting up.
Jan 21 15:30:52 avahi-daemon[6205]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jan 21 15:30:52 avahi-daemon[6205]: No service file found in /tmp/avahi/services.
Jan 21 15:30:52 avahi-daemon[6205]: Loading new alias name RT-AC88U.
Jan 21 15:30:52 avahi-daemon[6205]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.1.
Jan 21 15:30:52 avahi-daemon[6205]: New relevant interface br0.IPv4 for mDNS.
Jan 21 15:30:52 avahi-daemon[6205]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Jan 21 15:30:52 avahi-daemon[6205]: New relevant interface lo.IPv4 for mDNS.
Jan 21 15:30:52 avahi-daemon[6205]: Network interface enumeration completed.
Jan 21 15:30:52 avahi-daemon[6205]: Registering new address record for 192.168.1.1 on br0.IPv4.
Jan 21 15:30:52 avahi-daemon[6205]: Registering new address record for 127.0.1.1 on lo.IPv4.
Jan 21 15:30:52 avahi-daemon[6205]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jan 21 15:30:53 avahi-daemon[6205]: Server startup complete. Host name is RT-AC88U-DF60.local. Local service cookie is 2929183316.
Jan 21 15:30:53 avahi-daemon[6205]: Alias name "RT-AC88U" successfully established.
Jan 21 15:30:54 Samba_Server: daemon is started
Jan 21 15:30:54 miniupnpd[6233]: HTTP listening on port 53577
Jan 21 15:30:54 miniupnpd[6233]: Listening for NAT-PMP/PCP traffic on port 5351
Jan 21 15:30:54 wsdd2[6232]: starting.
Jan 21 15:32:02 syslog: WLCEVENTD wlceventd_proc_event(420): eth2: Auth 24:18:1D:40:1E:14, status: 0, reason: d11 RC reserved (0)
Jan 21 15:32:02 syslog: WLCEVENTD wlceventd_proc_event(449): eth2: Assoc 24:18:1D:40:1E:14, status: 0, reason: d11 RC reserved (0)
Jan 21 15:32:02 dnsmasq-dhcp[5404]: DHCPREQUEST(br0) 192.168.1.127 XX:XX:XX:XX:XX:XX
Jan 21 15:32:02 dnsmasq-dhcp[5404]: DHCPACK(br0) 192.168.1.127 XX:XX:XX:XX:XX:XX
Jan 21 15:32:54 syslog: WLCEVENTD wlceventd_proc_event(386): eth1: Deauth_ind XX:XX:XX:XX:XX:XX, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Jan 21 15:32:54 syslog: WLCEVENTD wlceventd_proc_event(401): eth1: Disassoc XX:XX:XX:XX:XX:XX, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Jan 21 15:33:29 kernel: usb 1-1: USB disconnect, address 2
Jan 21 15:33:30 hotplug[7100]: USB partition unmounted from /tmp/mnt/USB3
Jan 21 15:33:30 rc_service: hotplug 7100:notify_rc restart_nasapps
Jan 21 15:33:30 avahi-daemon[6205]: Files changed, reloading.
Jan 21 15:33:30 avahi-daemon[6205]: Loading service file /tmp/avahi/services/mt-daap.service.
Jan 21 15:33:30 iTunes: daemon is stopped
Jan 21 15:33:30 FTP_Server: daemon is stopped
Jan 21 15:33:30 wsdd2[6232]: Terminated received.
Jan 21 15:33:30 wsdd2[6232]: terminating.
Jan 21 15:33:30 syslog: WLCEVENTD wlceventd_proc_event(449): eth1: Assoc XX:XX:XX:XX:XX:XX, status: 0, reason: d11 RC reserved (0)
Jan 21 15:33:31 Samba_Server: smb daemon is stopped
Jan 21 15:33:31 kernel: gro disabled
Jan 21 15:33:31 avahi-daemon[6205]: Service "RT-AC88U-DF60" (/tmp/avahi/services/mt-daap.service) successfully established.
Jan 21 15:33:31 avahi-daemon[6205]: Got SIGTERM, quitting.
Jan 21 15:33:31 avahi-daemon[6205]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.1.
Jan 21 15:33:31 avahi-daemon[6205]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Jan 21 15:33:31 avahi-daemon[6205]: avahi-daemon 0.7 exiting.
Jan 21 15:33:31 Timemachine: daemon is stopped
Jan 21 15:33:31 miniupnpd[6233]: shutting down MiniUPnPd
Jan 21 15:33:31 miniupnpd[7121]: HTTP listening on port 34329
Jan 21 15:33:31 miniupnpd[7121]: Listening for NAT-PMP/PCP traffic on port 5351
Jan 21 15:33:32 dnsmasq-dhcp[5404]: DHCPREQUEST(br0) 192.168.1.22 XX:XX:XX:XX:XX:XX
Jan 21 15:33:32 dnsmasq-dhcp[5404]: DHCPACK(br0) 192.168.1.22 XX:XX:XX:XX:XX:XX Chromecast
Jan 21 15:33:32 avahi-daemon[7125]: Found user 'nobody' (UID 65534) and group 'nobody' (GID 65534).
Jan 21 15:33:32 avahi-daemon[7125]: Successfully dropped root privileges.
Jan 21 15:33:32 avahi-daemon[7125]: avahi-daemon 0.7 starting up.
Jan 21 15:33:32 avahi-daemon[7125]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Jan 21 15:33:32 avahi-daemon[7125]: No service file found in /tmp/avahi/services.
Jan 21 15:33:32 avahi-daemon[7125]: Loading new alias name RT-AC88U.
Jan 21 15:33:32 avahi-daemon[7125]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.1.
Jan 21 15:33:32 avahi-daemon[7125]: New relevant interface br0.IPv4 for mDNS.
Jan 21 15:33:32 avahi-daemon[7125]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.1.1.
Jan 21 15:33:32 avahi-daemon[7125]: New relevant interface lo.IPv4 for mDNS.
Jan 21 15:33:32 avahi-daemon[7125]: Network interface enumeration completed.
Jan 21 15:33:32 avahi-daemon[7125]: Registering new address record for 192.168.1.1 on br0.IPv4.
Jan 21 15:33:32 avahi-daemon[7125]: Registering new address record for 127.0.1.1 on lo.IPv4.
Jan 21 15:33:32 avahi-daemon[7125]: Registering new address record for 127.0.0.1 on lo.IPv4.
Jan 21 15:33:33 avahi-daemon[7125]: Server startup complete. Host name is RT-AC88U-DF60.local. Local service cookie is 1059000697.
Jan 21 15:33:33 avahi-daemon[7125]: Alias name "RT-AC88U" successfully established.
Try using a quality extension cable to connect the USB drive to the USB 3.0 port.
If issues still persist, use the USB 2.0 port instead, or, set the USB 3.0 port to operate in USB 2.0 mode.
The transfer speeds will be reduced to USB 2.0 standards, but the WiFi should not be affected anymore.
Thank you for answer but disk working, cable works, Aicloud works. How quality cable can make problems to 2.4 ghz network?
For me looks like when drivers of usb disk is loaded make some conflict with 2.4Ghz network
The 'quality' I'm talking about is the shielding a proper cable should have. :)
The RT-AC88U may have less than optimal shielding for the USB 3.0 port, internally, too.
The noise generated is in the 2.4GHz band...
:( I tried to connect other old external disk (usb 2) and works. I changed config port to 2.0 and works the new one to.
You are right! Thank you.
