RT-AC88U - Losing Wifi connection
Master3395
Hello, I've used Asuswrt-Merlin for years now.
In the last few updates I've been on my AC88U, the wifi has been quite unstable.
With cable, it works fine.
Wifi drops connection on both phones and laptops a lot.
Are there any suggestions to what I can check to make sure it does not drop the connection?
Wireless - Smart Connect Rule has not been changed (I have clicked reset to default)
DNS-over-TLS Server is as listed before.
I normally use CloudFlare and Google here.
Not sure if that has much to say.
Asus RT-AC88U (Asuswrt-Merlin) - 386.3
ColinTaylor
Part of the Furniture
Unrelated to your problem but you shouldn't be forwarding local domain queries upstream.
If the problem does not effect wired devices then it's nothing to do with your WAN settings.
Master3395
I don't know what forwarding it will do, but I don't see any big difference when I turn it off.
My whole router freezes up on both Wifi and Lan now. 386.3_2.
Not sure what I can do.
If I restart the router, it goes back to normal for the next 24 hours or so.
