RT-AC88U on Merlin 386.3_2 crashing/rebooting
Justinb
I've had some recent behaviour with this router where it seems to 'crash' and self reboot. Visting the System Log - General Log page it will say that the uptime is a few minutes after I've lost WIFI and eventually reconnected. I've been unable to reproduce the crash/issue but today installing a new WIFI device (soundbar) it again cause the router to crash/reboot.
Below is a cut of the log from two different crashes. From just before the crash and then the restart (Seems to start May 5 15:05 before it hits the NTP and corrects the date/time).
I'm at a loss as to what might be causing it and not event sure if I've got the appropriate "Message Log Level" and "Log only messages more urgent than" set correctly to try and catch this.
Any thoughts? should I be setting my log level differently?
many thanks
  • two_Crashes.txt
ColinTaylor
Part of the Furniture
Check how much free space you have in NVRAM (Tools - System Information).
Justinb
looks like (right now) just over 50% in use
Justinb
Hi everyone. The Router has just done the same again. self-rebooted / crashed. I currently have the following logging settings and below is the log. Any thoughts?
Nov 30 18:07:26 syslog: wlceventd_proc_event(527): eth2: Auth C2:CD:B3:C7:E8:F6, status: Successful (0), rssi:0
Nov 30 18:07:26 syslog: wlceventd_proc_event(537): eth2: ReAssoc C2:CD:B3:C7:E8:F6, status: Successful (0), rssi:0
Nov 30 18:08:09 syslog: wlceventd_proc_event(491): eth1: Deauth_ind C2:CD:B3:C7:E8:F6, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Nov 30 18:08:09 syslog: wlceventd_proc_event(508): eth1: Disassoc C2:CD:B3:C7:E8:F6, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Nov 30 18:11:24 syslog: wlceventd_proc_event(527): eth2: Auth 78:CA:39:B9:F2:67, status: Successful (0), rssi:0
Nov 30 18:11:24 syslog: wlceventd_proc_event(556): eth2: Assoc 78:CA:39:B9:F2:67, status: Successful (0), rssi:0
Nov 30 18:11:25 dnsmasq-dhcp[2324]: DHCPREQUEST(br0) 192.168.1.45 78:ca:39:b9:f2:67
Nov 30 18:11:25 dnsmasq-dhcp[2324]: DHCPACK(br0) 192.168.1.45 78:ca:39:b9:f2:67 AMMac
May 5 15:05:07 syslogd started: BusyBox v1.25.1
May 5 15:05:07 kernel: klogd started: BusyBox v1.25.1 (2021-08-06 17:47:26 EDT)
May 5 15:05:07 kernel: Linux version 2.6.36.4brcmarm ([email protected]) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Fri Aug 6 17:49:01 EDT 2021
May 5 15:05:07 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
May 5 15:05:07 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
May 5 15:05:07 kernel: Machine: Northstar Prototype
May 5 15:05:07 kernel: Ignoring unrecognised tag 0x00000000
May 5 15:05:07 kernel: bootconsole [earlycon0] enabled
May 5 15:05:07 kernel: Memory policy: ECC disabled, Data cache writealloc
May 5 15:05:07 kernel: MPCORE found at 19020000
May 5 15:05:07 kernel: On node 0 totalpages: 131072
May 5 15:05:07 kernel: DMA zone: 1024 pages used for memmap
May 5 15:05:07 kernel: DMA zone: 0 pages reserved
May 5 15:05:07 kernel: DMA zone: 130048 pages, LIFO batch:31
May 5 15:05:07 kernel: PERCPU: Embedded 7 pages/cpu @88407000 s6272 r8192 d14208 u65536
May 5 15:05:07 kernel: pcpu-alloc: s6272 r8192 d14208 u65536 alloc=16*4096
May 5 15:05:07 kernel: pcpu-alloc: [0] 0 [0] 1
Justinb
power supply all nice and tight.
I've had another crash/reboot again.. What I've noticed, however, is the last wireless device to connect is always my wife's MacBook (Mid 2010)
That's four crashes where the last line before the may 5 entries is
It could be a coincidence however.
Thoughts?
L&LD
Buy wife a new Mac? :)
L&LD
Maybe you should then. Just to get the 12-year-old Mac off the network. :)
L&LD
Doesn't seem to be working to me?
Tech9
Good enough to convince your wife you need a new router. ;)
Does it reboot with latest available stock Asuswrt firmware? It's newer than Asuswrt-Merlin 386.3_2.
