RT-AC88U port forwarding with LACP
spitfire915
Working on setting up LACP on the AC88U and ran into an issue. Router has LACP enabled, configured team as LACP in Windows Server 2012 R2, everything shows green/working across the board. I set a static IP for the new team, and everything is working on the LAN. For some reason, this broke port forwarding though. I have 3 services currently forwarded to the same static IP I set on the new teamed connection, however nothing external seems to be able to connect.
I should note that I set up the port forwards to NIC port 1 on the server first, then configured LACP afterwards. I assumed that my port forwards would remain intact given that they are forwarded to the same IP of the teamed connection. Does the bonded connection receive a new MAC or does it use the MAC from port 1? Do I need to delete and re-forward the ports to the new bonded connection because the forward is tied to the MAC and not the IP?
Any thoughts are much appreciated.
