Rt-ac88u vs rt-ax92u range
Andyandyandyandyandy
I’m currently using an RT-AX88U as the router with a RT-AC88U running in Bridge Mode in a cabin at the end of the garden. The connection rate hovers around 500Mbps with actual throughput of about 300Mbps using 5Ghz. There’s no one in my area to cause channel interference. Does anyone know if i upgraded the RT-AC88U to something like the RT-AX92U which would allow me to enable 160Mhz whether I might be able to get better performance. The internet connection is 500Mbps.
R High reliability and large range under 350? Wi-Fi Buying Advice 6
