RT-AC88U Wifi range problem with using IPTV.
Yasar KARAGOZ
Hi; is there anyone having this problem? I am using IPTV service from my ISP that name called Turkcell TV+ with Asus RT-AC88U. Everything is working great except Wifi range when IPTV set top box is on. 2.4 and 5 GHz range down to 3-4 meters.. And when switching off the box range is back to normal. Do you have any idea about it? Note: i have also tried it with RT-AC87U. No changes.
LAN>IPTV
Enable multicast routing (IGMP Proxy): Enable
Enable efficient multicast forwarding (IGMP Snooping): Enable
Wireless>Proffesional
Enable IGMP Snooping: Enable
LAN>IPTV
Thanks your answer. My settings are exactly the same you're wrote.. No changes
