[RT-AC88U] WLCEVENTD 401 420 449
no1san
I accepted already a lot of WLCEVENTD messages.
Background, one of the WLCEVENTD topics:
https://www.snbforums.com/threads/179-wlceventd-entries-in-one-second.60921/
Known issue Asus has to fix this.
I've seen the WLCEVENTD messages for ages
But there is one device (MINUT) generates al lot of messages. (examples below around 3 / 4 messages per minut)
Any tips to solve this?
Mar 15 08:32:51 syslog: WLCEVENTD wlceventd_proc_event(401): wl0.2: Disassoc macxxxx, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Mar 15 08:33:58 syslog: WLCEVENTD wlceventd_proc_event(420): wl0.2: Auth macxxxx, status: 0, reason: d11 RC reserved (0)
Mar 15 08:33:58 syslog: WLCEVENTD wlceventd_proc_event(449): wl0.2: Assoc macxxxx, status: 0, reason: d11 RC reserved (0)
That client is having connectivity problems. What is that client's RSSI in the wirelesslog? I believe that wl0.2 is your 2nd 2.4GHz Guest SSID? I'm not sure of the 88U interface mapping. Assuming its 2.4, what is your 2.4 GHz Roaming Assistant setting?
Also turn off Universal Beamforming and Airtime Fairness.
That client's location may allow interference (a neighbor's router on that channel?) that isn't detected at the main router. Have you tried a different 2.4GHz channel?
him
checking.
after this records it looks better:
Mar 16 17:40:18 acsd: selected channel spec: 0x100b (11)
Mar 16 17:40:18 acsd: Adjusted channel spec: 0x100b (11)
