Hello!
I am facing the following problem:
I have a router RT-AC86U firmware version: 386.7_0
For the second time in 3 weeks, OpenVPN profiles are erased on my own, and so are all routes.
I do not understand what it is connected with, here is what I found in the logs:
Can someone help me figure out what's going on?
Thank you.
Sep 1 07:35:26 ntpd: Initial clock set
Sep 1 07:35:26 rc_service: ntpd_synced 2290:notify_rc restart_diskmon
Sep 1 07:35:26 disk_monitor: Finish
Sep 1 07:35:26 disk_monitor: be idle
Sep 1 07:35:26 openvpn-routing: Configured killswitch on VPN client 4
Sep 1 07:35:26 rc_service: ntpd_synced 2290:notify_rc start_vpnclient4
Sep 1 07:35:26 openvpn-routing: Configured killswitch on VPN client 5
Sep 1 07:35:26 kernel: tun: Universal TUN/TAP device driver, 1.6
Sep 1 07:35:26 kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Sep 1 07:35:26 rc_service: ntpd_synced 2290:notify_rc start_vpnclient5
Sep 1 07:35:26 rc_service: waitting "start_vpnclient4" via ntpd_synced ...
Sep 1 07:35:26 ovpn-client4[2346]: --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Sep 1 07:35:26 ovpn-client4[2346]: Options error: You must define CA file (--ca) or CA path (--capath)
Sep 1 07:35:26 ovpn-client4[2346]: Use --help for more information.
Sep 1 07:35:26 openvpn: Starting OpenVPN client 4 failed!
Sep 1 07:35:26 openvpn-routing: Clearing routing table for VPN client 4
Sep 1 07:35:27 kernel: Init chrdev /dev/idp with major 190
Sep 1 07:35:27 kernel: tdts: tcp_conn_max = 8000
Sep 1 07:35:27 kernel: tdts: tcp_conn_timeout = 300 sec
Sep 1 07:35:27 ovpn-client5[2454]: --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Sep 1 07:35:27 ovpn-client5[2454]: Options error: You must define CA file (--ca) or CA path (--capath)
Sep 1 07:35:27 ovpn-client5[2454]: Use --help for more information.
Sep 1 07:35:27 openvpn: Starting OpenVPN client 5 failed!
Sep 1 07:35:27 openvpn-routing: Clearing routing table for VPN client 5
Sep 1 07:35:29 kernel: SHN Release Version: 2.0.1 851496c
Sep 1 07:35:29 kernel: UDB Core Version: 0.2.18
Sep 1 07:35:29 kernel: Init chrdev /dev/idpfw with major 191
Sep 1 07:35:29 kernel: IDPfw: flush fc
Sep 1 07:35:29 kernel: IDPfw: IDPfw is ready
Sep 1 07:35:29 kernel: sizeof forward pkt param = 280
Sep 1 07:35:29 BWDPI: fun bitmap = 83
Sep 1 07:35:31 A.QoS: qos_count=0, qos_check=0
Sep 1 07:35:34 rc_service: udhcpc 2160:notify_rc stop_samba
Sep 1 07:35:34 rc_service: udhcpc 2160:notify_rc start_samba
Sep 1 07:35:34 rc_service: waitting "stop_samba" via udhcpc ...
Sep 1 07:35:34 Samba_Server: smb daemon is stopped
Thank you.
