RT-AX3000 4TB Portable Drive Not Recgonized
ontwowheels
New RT-AX3000 router running the latest Asus firmware. Trying to add a 4TB portable drive, the drive is formatted 4TB NTFS, I see errors in the system log when it tries to mount. I chanted the partition to 2TB but same issue. Any suggestions? Below are what I see in the system log.
an 10 14:44:11 kernel: scsi 4:0:0:0: Direct-Access Seagate Portable 0712 PQ: 0 ANSI: 6
Jan 10 14:44:11 kernel: sd 4:0:0:0: Attached scsi generic sg0 type 0
Jan 10 14:44:20 kernel: scsi host4: uas_eh_bus_reset_handler FAILED to get lock err -16
Jan 10 14:44:20 kernel: sd 4:0:0:0: rejecting I/O to offline device
Jan 10 14:44:20 kernel: sd 4:0:0:0: [sda] Sense not available.
Jan 10 14:44:20 kernel: sd 4:0:0:0: [sda] Write Protect is off
Jan 10 14:44:20 kernel: sd 4:0:0:0: [sda] Asking for cache data failed
Jan 10 14:44:20 kernel: sd 4:0:0:0: [sda] Assuming drive cache: write through
Jan 10 14:44:20 kernel: sd 4:0:0:0: [sda] Attached SCSI disk
Jan 10 14:44:42 kernel: scsi host4: uas_eh_bus_reset_handler FAILED to get lock err -16
Another Seagate external drive issue. Are you able to format it on the router and reboot without any errors?
Thanks for the quick reply. The drive is not recognized, no USB attached, so the GUI won't let me format it. If there is a way to format via a command line I am unaware.
THANKS
@ColinTaylor may be able to offer you that command-line option, but without been seen at all by the router, I don't think it will help.
