RT-AX56U lose connections 2.4 an 5GHz on mobile
Ulrik
Hello
Hope to get some help here and that I cant explain it properly.
I have 2 RT-AX56U routers. One as a wireless and one as a node.
The problem I am going to describe, first occured when I got router nr 2 and set it up as a node.
The problem is when I walk around the house, my phone (galaxy s21 ultra) loses the wireless connection. It is with both 2.4 GHz and 5GHz.
So when I lose 2.4 GHz connection, I can switch to 5 GHz and it will work again. Same other way around.
It happens even on a great connection.
Hello
Perhaps my install notes will highlight some due considerations... or not... all I have time for at the moment.
When working properly, your client should decide to roam its connection from one node to the next as you move about.
OE
