RT-AX58AU firmware 388.1 issue QoS
Djurre Swets Pieters
My environment exists of 3 x AX58AU, wired connected and Mesh activated.
After enabling Adaptive QoS and looking into the WebHistory tab after one day my Webb Access gets frozen.
After a power-cycle of the router all seems accessible again.
Anyone else had this issue?
I think you will find that this is not limited to 388.1 Many have reported a similar issue with multiple routers over various releases of both Stock and Rmerlinware . Its closed source. If its a concern, you need to open a ticket with Asus
Same problem here exactly, it's not just your router. It's happened on my AX58U even back on 384 code. Just decided to leave web history off.
I have Asus RT-AX88U and Adaptive QOS /Web History not working either. I have a total of five Ai Mesh nodes all Asus and on the average, I have forty connected clients. My firmware for router has been 3.0.0.4.388.23748-g50a1620 and I have been using that firmware for months. The web history part was working until my two nodes, RT-AX3000 and RT-AX58u did a firmware update and it stopped. I must believe it's in the nodes firmware that caused the problem because it was working fine. You might check your firmware. I had problem Asus's auto updates, just didn't work for RTAX58u so I had gone to asus and find the exact same firmware and downloaded it to my PC first and then upload to the node. I am going shut my router off and restart and see if that works.
I hope I give you some ideas to try
