RT-AX58U Firmware 3.0.0.4.384_9354 -- 6/11/2020
Version 3.0.0.4.384.9354 2020/06/11 68.44 MBytes
ASUS RT-AX58U Firmware version 3.0.0.4.384.9354
- Fixed openvpn related issue
- Fixed Let's encrypt related issue
- Fixed Parental control issue
- Fixed system unstable when applying specfic iptv profile
- Fixed AiCloud share link bugs.
- Fixed AiCloud connection bugs with AiMusic App.
- Fixed AiMesh advanced parameters synchronize issue
- Fixed offline client removing problem with ASUS router app.
- Adaptive QoS supported more apps
Work-From-Home: WeChat Work®, RescueAssist, Tencent/VooV Meeting®
Learn-From-Home: LinkedIn Learning®, Binkist®, Skillshare®, edX®
Media Streaming: SiriusXM®, Bilibili®
Indoor training: The Sufferfest®, Bkool Fitness®, TrainerRoad®, Rouvy®
New errors in the log:
Jun 11 18:41:23 kernel: txerr mac 0300 phy a680 0000 2200 tst 2525 dur 000d
Jun 11 18:41:23 kernel: pctlen 0014 pctls 0b41 0000 0003 0000 0000 0000
Jun 11 18:41:23 kernel: plcp 0020 0000 || 040b 0000 0000 || 0000 0000 || 00
Jun 11 18:41:23 kernel: txbyte 0000 0000 unflsts 1ad0 usr 0000
Working good here. Wireless log not showing bug is also fixed in this build.
Don't know. The adaptive qos still won't limit upload speed. Still getting qos errors in log.
Does anyone from Asus ever read or reply here? Is there an official forum? Heck , I'm not even certain the firmware is faulty or is it my router? Worst tech support ever and I thought netgear was bad. Seems like all these home networking companies sell these routers with buggy firmware. Never fix it, then release a newer model with more bugs. Asus netgear tplink linksys. All crap!
Exactly the reason I use Asus with Merlin installed. I hardly have to mess with my RT-AX58U or RT-AX88U. My ZenWiFi XT8 is another story, that’s still a work in progress, no Merlin on that.
Rmerlin doesn't have the latest gpl for this router. I hope when he does get it, it fixed the qos problem. The bandwidth limiter and traditional qos work fine. Just adaptive qos will not limit bandwidth, so bufferbloat is crazy. Everything else about this router is 100% perfect.
I’ve never used qos on any router I’ve ever owned. No need for it, always had a fast ISP so it’s not something I would notice. Like you said other than that it’s great.
Same here never bothered with QOS buffer bloat is only present when the connection is maxed out. That is rare at least for me. AX58U works great on the latest stock firmware.
Well just reading around seems QOS is screwed up in many routers not just Asus. Good Luck hope they get it fixed for you.
