RT-AX82U - Cannot access LAN - Switch Control
AlanD
I'm using the latest firmware for the RT-AX82U : 3.0.0.4.384_9948
In the Web GUI, when I access the Advanced Settings - LAN - Switch Control, I can't change anything, I was expecting to have the ability of enabling Jumbo Frames and NAT acceleration.
But I can't apply and it looks as if the web page is corrupt, I need to hit the back button to exit the page.
Doe anyone else have this issue, or is it just me?
AT acceleration.
L&LD
Part of the Furniture
Can you try a different browser? Can you test with CTRL + F5? Can you test by using 'incognito' or 'InPrivate' mode?
Does a reboot help here?
Is the router in Router mode?
AlanD
I've tried Chrome, Edge and Opera, and same with CTRL-F5 and with Incognito mode.
I've tried a reboot, and I've tried reset to factory defaults.
And the router is setup as Wireless router mode , no AiMesh in use.
Do you have an RT-AX82U ? And you do not see the same problem as me?
L&LD
What antivirus are you using?
AlanD
It's exactly the same when I access the Web GUI on my iPhone, nothing to do with anti-virus.
AlanD
The issue was fixed when I installed ASUSWRT 386-7 beta firmware, which I found here :
