RT-AX82U Firmware updates to be supported ?
Tweakfiend
Hi Merlin & others
I only came across your website yesterday , so apologies if this has been asked before .
Are you , perhaps going to support the RT-AX82U model in the near future with firmware updates ?
I previously used the RT-AC68U, which some time ago auto downloaded a non useable firmware update from Asus, from which it did not recover , and was subsequently sent back to Holland for a refund !
So this question is of great interest.
I assume your downloadable updates for AX models stop the ability of Asus to auto update the firmware , as their system would not recognise your versions ( ?)
Regards
RP
L&LD
Part of the Furniture
Welcome to the forums @Tweakfiend.
RMerlin does not auto-update his firmware. :)
Tweakfiend
Thanks for the reply
I am aware from these forums that Merlin does not auto update software, but provides manual download links .
The questions were a) Can RT_AX82U be supported in future ? b) Would "administration " / "firmware upgrade" / "upload" options in router menu allow manual firmware updates from Merlin separately, and not overlap with Asus own process ? ;)
L&LD
You may need to read that post again if you're still waiting for an answer for the RT-AX82U.
Once on RMerlin firmware, there is no question of what firmware is installed, unless you do so deliberately or mistakenly.
TheOldMan
Question is why is DSL-AX82U firmware by GNUTon able to make Asuswrt-Merlin firmware work while there is a working RT-AX82U asuswrt-merlin compiler that was started in September and has been stagnant for months? I have a suspicion that the RT-AX82U performs better than the RT-AX86U. Anybody have any ideas?
L&LD
TheOldMan
Tech9
Have you wondered if it would perform better if it had Merlin's firmware?
It is going to have more configuration options, but everything Wi-Fi, AiMesh or TrendMicro related will be the same as original Asuswrt.
L&LD
There is no question that RMerlin powered routers perform better than any stock Asus firmware I've cared to test with.
I don't have the RT-AX82U, I would never buy that model (with or without RMerlin support), when the RT-AC86U is available.
I had the RT-AX58U, sold it first chance I had.
