RT-AX82U upload speed reduced after firmware upgrade
smartbits
I recently bought a RT-AX82U and after I configured it, my download and upload speeds both reached maximum levels, just like they did with my previous router. After I upgraded to the 3.0.0.4.386_45898 firmware, which is currently the latest one, my download speed still reaches the maximum but my upload speed has been reduced by at least 30%.
Has anyone else noticed this problem? If not, can anyone help me figure out which setting might be causing this issue?
Tweakfiend
Hi
The latest update is ........ 45934 which you can download manually , rather than use the auto update on the router menu c/o https://www.asus.com/Networking-IoT...ters-and-Systems/RT-AX82U/helpdesk_knowledge/ Have used this for sometime with very consistent upload / download levels.
smartbits
Hi
I first tried updating manually but it did not work. I actually had to reset the router in order to perform the update. I am not on the latest version. I also reset the router after upgrading the firmware.
Tweakfiend
In Router menu , Go "Administration " / Firmware Upgrade " then to "Auto Firmware Update" = Off , then Ai Mesh Router /Upload ( Point it to the downloaded file from my previous link ). Not sure how this could be a problem
