Just thought I post my experience here regarding the 2.5G port on my AX86U. I am using a Asustor AS4002t NAS. When the AX86U came out, I purchased it thinking I could use the 2.5G port to connect to my NAS 10G port and get a 2.5G connection. It even advertises on the box that you can connect PC and NAS at 2.5G using that very port. Sadly that is not the case.
My AX86U did not detect my NAS upon connecting the 10G port to the 2.5G port. The connection was detected as 2.5Gbps on the status tab, but the NAS does not appear on the list of devices and does not get assigned an IP address via DHCP. This is with the CAT6A cable that is supplied with the NAS. I also tried various other CAT6 cables that works fine. The NAS works fine when connecting the 10G port to the AX86U Gigabit port with Gigabit speeds using the NAS supplied CAT6A cable, but that defeats the purpose of buying this combination.
After some back and forth communication with Asus Support for nearly a month, with 2 firmware updates and a couple of factory resets in between, they concluded that the AX86U 2.5G port is not compatible with the AS4002t 10G port. You would think that they would at least test compatibility with their own/sister brand products but I guess that is not what happens in this company.
They did say they will issue an update in the near future that should fix this incompatibility, but in my mind, ethernet should be plug and play (assuming that there is nothing wrong with the client or the ethernet cable). Looks like this is the 2nd time Asus has failed me with their ethernet connections. The 1st one I have documented here in this very forum with my AC68U.
If you guys have any experience, good or bad regarding the 2.5G port on the AX86U, please share them too. Maybe it'll help Asus if they read this forum. I really hope they can fix this issue, as if they don't, this is what you call false advertisement dear Asus and you are sure to see me in consumer court if I don't get a refund.
