GuinevereB3ck
Upgraded my setup from the SR203 G-Fast router to a Draytek 166 and Asus AX86U plus a pair of ZenWiFi AX in AiMesh mode – backhaul mode ON.
The Asus router was flashed with the 386.1_beta3 (tried 4 but I had to roll it back due to some legacy wi-fi devices dropping out the network) since all devices are stable.
After rolling back the firmware the device was factory reset and reconfigured from scratch.
Then I have deployed a Cisco Meraki switch MS120-8LP with RSTP enabled.
The issue I am having is that randomly all devices seem disconnect for a few seconds and reconnect again. Tried to identify a pattern but there is none.
Have seen this while playing online as the session kicked me out and then when I reconnect works like nothing happened.
Checking the time against the logs the following is reported:
Jan 19 15:43:52 kernel: CONSOLE: 302326.025 MQ: wlc_tx_fifo_sync_complete: fifo 4: collected 3 pkts
Jan 19 15:44:12 kernel: CONSOLE: 302345.632 MQ: wlc_tx_fifo_sync_complete: TXPENDTOT = 0
Jan 19 15:44:12 kernel: CONSOLE: 302345.632 MQ: wlc_tx_fifo_sync_complete: fifo 4: collected 2 pkts
Jan 19 15:44:32 kernel: CONSOLE: 302365.240 MQ: wlc_tx_fifo_sync_complete: TXPENDTOT = 0
Jan 19 15:44:32 kernel: CONSOLE: 302365.240 MQ: wlc_tx_fifo_sync_complete: fifo 4: collected 1 pkts
Jan 19 15:44:52 kernel: CONSOLE: 302384.847 MQ: wlc_tx_fifo_sync_complete: TXPENDTOT = 0
Jan 19 15:44:52 kernel: CONSOLE: 302384.847 MQ: wlc_tx_fifo_sync_complete: fifo 4: collected 2 pkts
Changed the MTU and the router was reflashed twice.
Any idea what this is?
Cheers,
G
Cheers,
G
